the lone gunman
- Oct 30, 2005
ok i have been using Vista since bata and i now have a fully up-to-date copy of vista on my PC. however i still have the same problem as i did back in the beta days:
sometimes when i want to "move" or "copy" a file (one that takes more than a few seconds) i get a message on the progress bar (not responding) even though i know the action is still taking place, however if you just wait a while the file will be moved or copied successfully.
this problem does not occure if i move or copy a file then just leave the computer to it and perform no other actions e.g: open web page, open aplication ect...
The only time this happens is if i open another window over the top of the progress bar. i know the action of moving of copy is still taking place because i have waited so many times in the past and eventually the file is transported in the allotted time, its just the progress bar reports back as not responding.
i move and copy alot of files and i never had this problem with XP, my PC isnt slow (spects at the end) its just most of the time if i move a file thats, say 10gb, i dont want to just sit there for 3-4 mins whilst it does it, i want to carry on doing whatever im doing.
like i said i know the action is taking place but why does the progress bar "hang" when i carry on with my work after moving and copying?
PC:
Q6600
8600gt
4GB ram
1TB hdd
P5Q
Vista
any one else had this problem?
PC:
Q6600
8600gt
4GB ram
1TB hdd
P5Q
Vista
