D
Deleted member 169154
Guest
Last week I installed Vista using a clean install. In the Vista installation setup I deleted the entire hard drive, formatted it, and installed Vista. I noticed it didnt have the same performance that a fresh install of XP had, moreso than I assumed a performance hit from Vista would make (I use an OCed C2D @3 GHz, 4 GB Ram, raptor HD).
My theory is because it wasnt fully reformatted. Like in XP, when running from the CD, you go through all the blue screens, click delete partition, non-quick format, and then it takes a long time saying formatting, and then after it spends 1-2 hours formatting, it then installs XP. In Vista. I clicked delete partition, it said deleted, and then went straight to the installation, and completely skipped the long formatting process.
I also noticed when running Vista that my hard drive ALWAYS seemed to be accessing something when using Vista. I would like to discover a way to FULLY reformat Vista and not their crappy version saying it is reformatted and then finding it doesnt seem to be.
