Boardin087
- Jul 2, 2003
I can get it for free? What am I missing out on with it?
You only list 1 GB of memory, so there won't be much you would be missing out on, in terms of it being 32 bit. Besides, your key will work on x64 media, so you have that option.
Originally, I was going by the 1 GB in his sig. The 4 GB part didn't get mentioned until later on. If a system is running 1 GB only, there's definitely nothing to be missing out on by running Vista x86.if by 1gb you mean 4gb, then yes
I'm using Vista Business at work and I love it. You'll be missing out on extremely faster load time on your common business apps thanks to Superfetch. Office 2007's heavier footprint compared to 2003 will cease to be noticable when you run it in Vista, at least in my experience.
For the record, I'm using an Intel C2D T7500 2.2GHz and 2GB RAM HP Compaq 6710b Business Notebook at 1680x1050 and I couldn't be more happier.
Slap in another gig of RAM in your box and I think you'll be pretty satisfied too within a week or two.
I don't recall Aero being disabled by default, unless you don't have video drivers installed. That's just normal, for Vista.I'm using Bussiness version at home and don't feel anything missing
But then again i haven't noiced for a week aero is disabled on it by default
BTW when you instal it don't run screaming omg it sux i want xp immediatly - give it a week or two and you will see it's better system.
On the other hand, you will get a feature that's not on the home edition. Previous Versions. This feature alone makes Business preferable to home for me.
are you talking about compatibility mode? I'm almost positive all of the vista versions have it.
I think that is a waste of my HDD space, personally.
