infornographer
- May 7, 2008
XP was a skinned classic interface.
Wrong. XP's interface was called Luna, and it's just about as much a reskinning of Classic as Aero was a reskin of Luna.
Vista is more than that now (Aero). You either get classic or Vista.
or some would argue less. It wouldn't have required much of them to do it, at all. It's called laziness.
I highly doubt they'll EVER had back-versions of Windows. You'll always get the current version (Vista) and a classic version.
That's because they were LAZY. : )
I just don't understand why this is a big deal though... Black (And better performance) vs. Green images.......
You honestly believe Aero performs better than Luna? Aero may repaint a little better, but I actually prefer Luna's behavior, and that glass mac ripoff looks like shit. I can only stand that DX-enabled scat porn for so long. If you really think black vs green is what's at issue here, go back to preschool and play with your crayons.
I guess they *could've* added in the XP theme, but then people would be bitching how much more bloated Vista is adding that crap in.
And where on earth do you see they are adding the XP theme back in?
It isn't just the THEME, and if you think adding customization options has anything to do with bloat, you're vastly mistaken about the meaning of bloat. Bloat would be having more things run resident. Nonbloat would be a series of easy options that allows a user to set which roles they use Vista for or display preferences. Options aren't bloat. Forced "features" are.
I didn't say they were adding it back in. They were filling out the skinned monstrosity's options. They finally added one familiar UI feature to resize the search bar that you CAN'T FUCKING REMOVE, and oh, let's make it so you have to buy a new OS called Windows 7 to do it! (unless maybe you enlisted some programmer's help to HOOK into the exe, which doesn't count.) It's a fascist design policy that arises from laziness.
(To anyone who thinks Windows 7 is irrelevant, you're wrong. Windows 7 Milestone 1 exists with confirmed changes via official screenshots, and that's what I'm referring to, and you can bet you aren't getting any of that in Vista. They slapped you in the face.)
Luna isn't just the default skin either. It's the whole design scheme that came with it.
This visual style is arguably better than Aero, and it's built on the basis of Luna:
Oh yeah, that address bar can be moved around. High tech shit, huh?
