ok then. After changing one file name in the system32 folder i attempt to restart and i get the dreaded BSOD. I attempt to restart in safe mode and it stops at crcdisk.sys and then i get a BSOD.
After many google searches later and no fix i end up here asking for insight. I attempted to boot from the disk but to no avail.(I will try again using the dvd drive as the only boot option) I tried to install xp on my empty slave drive after placing it in the sata 1 slot and completely removing the other drive and got bootmngr could not be found, press ctrl alt delete to restart.
I guess the goal at his point would be to some how save the data on the hard drive with vista on it if it can not be fixed. =( /sigh
comp specs as follows:
Processor: Intel(R) Core(TM)2 CPU 6320 @ 1.86GHz (2 CPUs), ~1.9GHz
Video Card: NVIDIA GeForce 8800 GTS
Operating System: Windows Vista Ultimate (6.0, Build 6000) (6000.vista_gdr.070627-1500)
Mobo: MSI dual PCI-E name i forget
RAM: 2x1gb sticks of crucial ballistix
p.s. this is the 64 bit version of vista ultimate. also any other info needed from just ask. Thanks in advance.
edit: corrected to crcdisk.sys and i tried to boot only from the dvd drive and it completely ignored it. *sadpanda*
