Does anyone know if Vista and the Intel Quad Core QX6850 Extreme is compatible? I can't even get it to load Vista.
Basically I have a retail DVD of Vista Ultimate and I put in the 64 bit disc. It says "Windows is loading the files", then gets to 100% and then restarts. I've tried it with the 32 bit disc and tried multiple times, unplugging everything except for HDD, optical drive, video card. I also disabled basically everything in the BIOS for like LAN and Audio. Still loops.
So I pop in another processor that I had here (a C2D E6550) and it boots up no problem at all. So I install Vista, get into Vista, and turn her off. I then swap the processor again to the QX6850, and Vista WILL NOT load. After the first failed attempt it brings you to the screen that you can pick safe mode, so I did, and it loops.
Suggestions? This is Vista Ultimate DVD (retail) that is the original version (purchased probably 6 months ago). Is there some type of Microsoft patch or anything I should know about? The motherboard uses the 680i North Bridge. It has 2GB of memory on a single stick.
