using orthos now, which I really like, thanks. was using prime95 but vista 64 would kill it if i started it from a shortcut. i had two shortcuts set up to run two instances of prime95 to test both cores. i'm actually really excited that you do not have to do that with orthos. there probably was a better way to test two cores with prime95, but i was not aware of one.
link to download?
Doesn't the newest version test all cores?
link to download?
