Vista and MCE: Multiple drives?
jkrafcik
My HTPC is running Vista RC2 (Ultimate), and before I go out and purchase retail Vista (Home Premium upgrade) I want to make sure there is a way for me to add multiple drives.
Navigating through the MCE interface, it appears that I can only set 1 drive as the recording drive at any particular time. In other words, if I run out of space on 1 drive I have to manually switch to the other drive. When 1 drive gets full, it starts to delete content from it. If I start to run out of space on Drive 2, content will be deleted off of it. When I then try to figure out which content is on Drive 1 or Drive 2 so I can better manage my own space, there's no way for me to figure it out inside MC. Argh!
If I recall correctly XP MCE had a way to manage 2 or more drives simultaneously. Anyone know how to set it up so it intelligently records on 2 or more drives? I'm guessing there's a way I can do it with drive pooling, but that would require repartitioning, reinstallation, and also this would only work in Ultimate and not Home Premium (and I can't buy an academic version of Ultimate, so I'd have to pay about $160 more).
Thanks!
why not set up a raid 5 ????, u can use add in cards for this or simply use the onboard stuff..
The drives are substantially different (160 gig SATA vs 250 gig USB 2.0). I also want to be able to map excess capacity from my desktop computers that are always on and add them to my media storage pool.
RAID is not at all attractive since it either cuts reliability by half or increases cost per GB significantly, and requires very similar (i.e. new) hardware.
I'm using Vista Premium and I do remember a setting in there to set multiple storage drives for recording. Haven't actually tried it but I'd imagine it would put the files where there is space.
RAID is actually meant to increase reliability so assuming you had identical drives it would be the way to go. Definitely costs a bit more but can also definitely be worth it. Also for media servers RAID5 is a rather attractive feature to have if done properly.
I will be backing up my media on a separate home-built NAS, so storage is more important than reliability.
