senorcarne
- May 17, 2007
I just got a 2nd monitor, rotated 90 degrees, and it's so awesome. It's to the left of my main monitor (with the taskbar) and set up perfectly.
There is one problem though: Vista's transparent taskbar. It's on the second monitor, like it should be. But that screen is 1680x1050, and the left screen (the new one) is 1024x1280.
For some reason, on the right display, 1024 pixels of the taskbar are transparent over the other monitor. Meaning, that when I look at the taskbar (which is on one screen only), it's fully transparent, but 1/2 of the transparency shows the wallpaper of the OTHER monitor, and the other half shows the wallpaper of the 2nd screen monitor.
Does anyone know how to fix this?
