vista aero interface
xrAph
Hey guys. I just installed Windows Vista (Build 5308). It was a smooth install process, and overall I'm happy with how it looks and reacts (a little laggy at times tho.)
Is the 3d interace disabled by default? I saw a few screenshots of this build (on the pcmag website) with the alt-tab window displaying 3d representations of a all the open windows. How do I enable and access that feature?
Thanks.
They may have ditched that feature. I don't see anything relating to it anywhere.
I do not remember what the specific key combonation is, but the "Flip 3d" thing that you are talking about is not alt-tab, alt-tab still works pretty much the same, the Flip thing is a different key combo (windows key -tab maybe? ) Sorry I cant remember.
Win-Tab for flip3d
For regular Flip, it's the plain Alt-Tab. If it's NOT comming up, reboot your machine. For me, after install it never did it untill I rebooted the machine.
DocNsane,
Just a quick question, did you install Vista on your Asrock? if so what bios are you using? it wont let me install it, just keeps coming up with errors.
