roshambo14
- Jul 26, 2004
I just built a new box for gaming, and decided I wanted to try out Vista Ultimate 64bit. Battlefield 2 is the game I play the most by far, and it seems to run great, for a couple hours at a time at least. After about 3 hours or so, I get this error:
The description for Event ID 0 from source cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
6
Anyone have any idea what that is? Machine specs are AMD 5200 X2, 8800GTX, 2GB.
6
