Rig in sig.
I had a complete melt down two days ago, and I'm trying to trouble shoot the problem.
I started Vista 64 and chkdsk wanted to run on boot, so I let it. It said it found errors and then proceeded to "replace invalid security IDs with default security IDs." Afterwords, the system wouldn't boot.
I couldn't get Acronis to reimage the array, so I deleted it and reconstructed it. After that, Acronis allowed me to restore it.
OK, so then I scheduled a chkdsk for reboot and something similar happened. I can't tell you what check disk did because I had the GUI on and it covers up the CD process. But I know it didn't do the security thing because that took about two hours. This last check took about 3 minutes, but with the same result--and unbootable system. It would boot to a point I had mouse control, but would give me a black screen, no CTRL-ALT-DEL nothing. Hard boot only way out.
The first time Vista blind sided me because I didn't schedule a check disk on restart, and on shutdown, I had no problems either. At this point I'm thinking one of two things: (1) check disk is incompatible with RAID 0 on Vista 64 SP2 or (2) Bad WD 640 Black. My next test is to delete the array, boot with an external drive, and run WD diagnostics on each disk--since you can't run a disk analysis tool (that I've found) when using RAID.
What do you all think?
