Vista 64 on old P4 Machine?
Gary1951
I"m curently running XP SP3 on my P4 3.2 with 4 gig of ram. Of course as you all know it only reconigizes 3.58 or so. I was wondering how it would run with Vista Ultimate 64. I do not game on this machine anymore. Do Internet, Email and Photography stuff on it. I run Olympus Studio2, Olympus Master and Adobe Photo Elements 6. Any sugestions and advice would be appreciated. Thanks in advance.:confused:
One of the big issues is that even if you go to a 64bit os your motherboard may not allow you to still see all 4 gigs of memory. A lot of the older boards that could only support 4 gigs of memory would still put the pci addressing space in the 4 gigs and not above it. A bunch of pentium d boards had the same issue. Pretty much you would still prob end up only seeing 3.5 or so gigs. This is a hardware limitation of the chipsets and not an os one.
Personaly I would look at upgrading before doing the switch anyway.
It's just a system the guy wants to put Vista on to click around the net on, not a gaming or productivity machine.
Download CPU -Z (cpu id) and check this list to see if it'x x86-x64 compatible, based on description of cpu in the cpuz window http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors
He wants to get full use of his 4GB. We're telling him that 1) he may not be able to since his processor could not be 64-bit 2) His chipset may not allow him to use all 4GB even though he has a 64-bit OS.
If both of those things aren't going to be problems, then by all mean go for it.
