Z
Zinn
Guest
I've tried two different versions of the disc image, a legit one I got from an MS Action Pack subscription download, and a not so legit one that I tried in desperation. In both cases, the installer loads the setup files, shows that same little startup bar Vista does when it's booting up, and then goes to a black screen instead of the GUI installer. Sometimes it goes into the graphical screen and shows the background and the mouse cursor, which you can move around, but I left it there for an hour and the Installer still didn't come up. Arrg.
I'm using an IDE DVD drive, could that be the problem?
I've tried this at stock speeds, to take overclocking out of the equation.
I tried burning discs on a different drive using different media, no avail.
Does anyone know what I could do to get this to Install?
