Vista 64 Install Order
I ordered a corei7 system it will be here next week. I want to go over just the basics of setting everything up right, ive done this before many times maybe some of you have new suggestions or better/easier way of doing things, so here goes:
1)Install all the hardware, power on the system, make sure everything is running, no mobo codes.
2)Set up bios defaults, update to the most recent bios from the manufacturers site.
3)Enable AHCI mode in the bios then install Windows Vista on my Raptor150ADFD
4)Install all Windows updates
5)Install Chipset Drivers
6)Install Video Drivers
7)Install Audio Drivers
8)Connect backup/storage drives
9)Whatever else left over mouse/keyboard/ipod...
Note: Im going to have the Raptor150ADFD as os/boot drive and WD640AAKS as my gamedrive
Note: Does AHCI work with all sata? I believe my Raptor is sata 150 not sata 2
Note: How does this work with my sata DVD-RW?
1) Set up the mobo and the BIOS, update if necessary (if you do, set it for Optimized defaults, then reboot after the update, do it again, reboot, then set all the options as you wish, including AHCI.
2) Install Windows.
3) Install chipset drivers.
4) Install storage drivers if necessary (like the Intel Storage Matrix) at this point.
5) Install your NIC driver if Windows doesn't have one for it by default, then hit Windows Update and grab everything you can, reboot if necessary and go back and hit it again, repeat, till it says there's absolutely nothing left for updates.
6) Now install the latest video driver if you want, as I prefer to get a system fully functional up to this point using only Windows Update drivers if they exist and then updating those to the latest ones direct from the manufacturer if they do exist.
7) Audio will most likely be covered by Windows Update but install the latest ones if necessary for additional functionality.
8) The rest of it, meaning applications, etc.
9) Image that sucker right then and there after a reboot and to make sure it's clean as a whistle and everything works.
10) Done.
What Joe said, but between #8 and #9 I would perform basic clean up and system maintenance. Clean up your shadow copies and restore points, get rid of any Win features you know you will never use, run disk clean up, and finish off with a defrag. (I know Vista and Win7 don't need it as badly as Xp but a defrag can't hurt prior to imaging.)
For myself, I also typically uninstall the vid card drivers prior to the initial imaging. I do this because I do not have to restore from an image often. And when I do, the first thing I am going to do after hitting the Windows updates site and updating my AV, is download and install the latest video card driver anyway.
sometimes upgrading the bios(if previously your pc has been working gr8 with your current hardware) might not be a wise decision :) ive had quite few cases on my setups wheer i got really bad issues after bios updates....but well it depends on the day i guess ":)
