bigdogchris
- Feb 19, 2008
Well here's my ordeal, and I need advice.
I got Vista 64 up and running great, system and OS is all stable but I'm having a lot of problems with gaming. Crysis keeps crashing no mater what combination of 64/32 bit or dx9/10 or sli I run. 32 bit crysis crashes almost immediately after I start it. I also run Vegas 1 on it, and it crashes, with that one nvidia error where it recovers after a few seconds. I thought maybe it was hardware so I reinstalled XP to test, but have been playing crysis for 2 days w/o a single problem.
Is SP1 giving me issues? Is Vista 64 truly this buggy? I'd consider Vista 32 bit but when I tried that I only saw 2.2gb of ram but XP see's 2.7gb. (yes I understand 32 bit limitation, just pointing out that if I'm going 32 bit I will go with XP)
I'd like to stick with Vista 64 to be able to use all 4gb of ram but what's the point if it keeps crashing.
Under 64 bit I have the most updated drivers and disabled NCQ but nothing seems to fix the crashing.
What should I do? Just deal with it and hope for Driver fixes?
