Vista 64 bit, 64 bit apps as default
scotlandrocks
OK, Vista 64 is set to use Internet Explorer 7 32-bit as default and Media Player 32-bit as default.
I'm looking for an easy way to set everything to run native 64-bit. Anyone know all which apps are set to default to 32-bit and an easy way to change them over.
Yes I know there will be problems, codecs not installing and flash not working.
Cheers
If you don't want to run into massive compatibility issues between 64 and 32 bit software, just leave it alone.
Install 64 bit apps where possible- is all you can really do. Otherwise you are asking for more of a headache than it is worth.
