XP64 is based on Win2K3 code, not XP32. There won't be a "SP3 for XP64" until there is a SP3 for Win2K3. For reference, SP2 for Win2K3 just came out earlier this year.64bit... if at all possible dual boot with XP-64bit and Vista-64bit... recent articles showing XP expecting a good performance boost over Vista with the SP3 soon to be released.
Thanks, I plan on trying that duo boot setup with vista 64 bit and xp 32 bit.
i wouldnt even bother personally, everything works on 64 bit vista for me just fine and i use tons of apps. i dont know how everyone used to complain about vista but maybe these little updates they release every so often really has changed something because my experience is flawless. i cant even remember the last time i logged into xp. im about to delete that piece of crap.
Their are multiple benefits of a dual boot and/or triple boot setup.
First if one OS gets a corrupted registry, virus, corrupted file, etc... it's easy to boot into another OS finish important work/games then fix the busted OS at your convenience.
Second a multi-boot environment makes it easier to fix a busted OS.
Third one type of OS might have better performance and/or game stability for some games than another type of OS.
Fourth if a problem occurs it's easy to discover if it's a hardware problem or software problem with a multi_boot setup simply by booting into another OS. A single OS will not provide this benefit.
I'm not sure why people think on is better (for everyone, blanket statement) or why no one searches for the other 2,732 times it's been asked.What is better, 32 or 64 bit? Thanks.
vista has burning built in...I've had 64-bit Vista damn near since launch, and I just ran into the first instance of a problem that made me cobble together an old 32-bit box: disc burning.
Mind you, Nero works fine and dandily, but the good ol' tools of yesterday: CDRWIN, DiscJuggler, and many many others that need/depend on an ASPI layer don't work under Vista, so I needed another box to burn console-compatible CDs with any degree of success.
you can use vista firewall control to allow or disallow incoming/outgoing connections and set a rule for them on vista's own firewall which is up to par with any other these days.I'm all about Vista x64 - been running it for over a month now and love it.
A few bummers about it - no good x64 Citrix client available and Zonealarm has no plans of making a 64-bit version of their firewall.
That sucks.
