I used the ATI Catalyst tool to OC my card, and it says 500/1090 in the current clock settings. I have ATI Overdrive enabled, and there it says GPU 780, Memory 1090. Idle temp is 81c.
I am running Catalyst 8.6.
What's going on here????
EDIT to add. I can't get the refresh past 60 hertz, running a BenQ G2400WD monitor, is that right, or should I be able to pump it up a little?
