Visiontek ti4200 fan replacement
drkavnger99
Just figured out why I'm having so many problems playing games for any extended period of time. It seems the fan has died on my Visiontek ti4200. Anyone have some suggestions for good replacement fans that occupy about the same amount of space as the stock one. I'm not overclocking it so just need a simple solution here. You guys have helped me in the past and I look to your expertise. BTW I did google it but there are several selections and I haven't a clue on the reliability of these things so I look to you. Appreciate all input thx!
You did say same amount of space; for that, the vantec cooler B2W listed is good. If you don't mind taking up one more slot though, consider this:
http://www.newegg.com/app/ViewProductDesc.asp?description=35-186-117&depa=0
Arctic Cooling's NV Silencer 1 is very quiet, and has a fan that will last. It'll also lower your case temperatures a bit too by ducting hot air out the back of your case. If you search around, you might be able to shave a couple of bucks off the price. One Newegg "review" mentions that it fit on your card with no problems.
Thanks for the suggestions and you turned up one I was considering in my first search it looks as if I will go vantec. The Artic Cooling one would be nice but will not fit due to me being an a$$hat and having all my pci slots filled (note to self next time get all the features onboard that I want). As usual you guys are to the point and more than helpful!
