visiontek radeon 4870 2x troubleshooting help!
I have the corsair 750w psu, wolfdale 3.16 cpu, seagate 640, asus p5q pro,
everything is hooked up and all the fans are working fine when i boot up the pc with power. however there are red lights on the back of my gpu and nothing is coming up on my monitor.
three of the 5 lights are lit up red. as best as i could read the numbers here they are;
R753, R724, R819, they are the first three in a row starting from the back of the card.
The lights do not flicker, they start up solid and stay solid red.
I have stand off posts underneath the mobo. I'm confident everything is connected correctly. I have both power things hooked up. one with 8 prongs, one with 6. the card is in the blue pci express slot. I have a tv tuner card in the pci slot above it. They aren't touching or anything.
Anybody have any ideas I could try? Is this card DOA?
For what it is worth I had exactly the same deal with the trouble lights and blank screen on start up when I first started my system after installing the 4870 x2...but in my case it was because a screw from my water block was making contact with the card...as soon as I removed the screw and reinstalled it with a pvc washer the system instantly worked fine...I know you mentioned using risers but based on my experience I would look for some electrical contact.
Good luck, let us know.
so should i replace all the risers with plastic ones or something? maybe a plastic washer in between the card screw or something?
i double checked that i have all 9 risers behind the mobo. I took out the tv tuner card that was sitting above the gpu. Same three red lights are solid when I power up... grr
I don't have a water cooling system. I can't see anything touching the video card save for the two power cables I have plugged in. :( this is the part of building that annoys me
Is there anything else you think could be causing these red lights? Is the card possibly dead? I've got the limited 30-day return policy on newegg for this card... ahh!
