When using the Vision Engine Control Center, under "3D Application Settings", if I set it to "Override application settings" for a specific game .exe, it will not apply the settings. The same settings do work if I apply them globally (under "System Settings"), so it's not a problem with the game or the hardware or anything. Here is an example screenshot:
UT2K4 should have 8xEQAA applied, but it shows aliasing: Screenshot
When applied globally via "System Settings", it works as intended: Screenshot
This happens with any specific game, and any forced settings (AA, AF, Vsync, etc.). Is it just me or is this just a bug? I'm using the 13.3 beta 3 drivers, with a 7950, though the problem also occurred with my old HD 6770 (which I also used with 13.3). I vaguely remember it working properly for specific games when the new profile system debuted in 13.1. (or some time around then)
Edit: Update: So, turns out it was just that specific driver - just installed 13.5 beta and custom game applications apply properly again. Thanks for the replies.
