Here's the thing, I opened a suspicious file, like a dumbass, after I formatted, forgetting I hadn't put an AV on it yet...immediate forced reboot...then when it reboots I get BSOD with error code 01E...which windows states is either hardware, (CPU, Motherboard, or Memory)...
I've gone from Vista 64, to Win 7, back to Vista 64 on this machine, which was built in 2008. Is my motherboard going bad, or CPU? I can't run prime because Windows BSOD before I have the chance to due much of anything. My bios are up to date (2009, meh Asus). Before when I was having this problem, I switched to Win 7 and everything was fine except for annoying Validation checks; prior to that I had used Vista 64 for 2.5 years...I did a memory scan a few weeks ago for 24 hours and it came back fine.
I am guessing I should format then run Prime to test for CPU problems and go from there. I doubt I can RMA the motherboard if that is the problem it is probably past its date...
