Hi
My current machine is approaching the 6 year mark and although it's still going pretty well it could do with an upgrade considering how much I use it for my work and studies.
Currently I have:
This machine has been absolutely fantastic and I use it every single day and (touch wood and all that) it has been rock solid but I'm finding that with all the virtualisation I do with VMware Workstation Pro for work and my studies that I sometimes run out of resources.
I'm also finding that 4k videos sometime stutter or drop frames so I have ordered an EVGA GeForce GTX 1050 video card so I don't have to use the onboard Intel HD4000 anymore.
Things sure have changed since I bought the above system with AMD coming out with some killer CPU options!! Considering that I will be using the machine for email, internet, virtualisation and watching 4K videos is AMD a good choice? It absolutely must work with Windows 10 and VMware Workstation Pro 14. I'm still trying to decide if I should go Ryzen or Threadripper? AMD or Intel?
I was thinking of the following for a Ryzen setup:
I haven't decided on a budget yet but the above costs about £800. I'll be reusing my current drives so no need for new ones. Same goes for my dual screens.
A Threadripper setup is more expensive (obviously) as is the Intel i9 platform so I'm wondering if its worth spending the extra considering that I will use it mainly for virtualisation?
I can easily bottleneck my current setup when I spin up a test nested vSphere environment (maxes out all 4 cores on the CPU sometimes) and although the RAM usage can get high I think 32GB is fine for now but upgrading to 64GB later on is a nice option to have.
Booting off the M2 NVMe drive I have is a must!
Look forward to any advice or comments
Edit: I'm looking to upgrade in the next 6 months and I don't overclock or game
Currently I have:
- Intel i7 3770 3.4ghz with BeQuiet BK017 CPU cooler
- 32GB DDR3 1600mhz (4 x 8GB)
- Asus P8Z77-V Deluxe motherboard
- Samsung 850 Pro SATA SSD 256GB (boot drive)
- Samsung 950 Pro NVMe SSD 256GB (virtual machines)
- 3 x old school spinning disk SATA drives ranging from 2TB to 6TB
- Fractal Design Define R4 case
- BeQuiet 850W PSU
- Ryzen 7 Eight Core 1800X 4.00GHz
- Asus ROG Crosshair VI Hero AMD X370
- Vengeance LPX 32GB (2x16GB)
