damarious25
- Dec 27, 2010
Sorry to bother everyone but I'm just reaching out get a quick opinion. I currently use VirtualBox but the problem is I keep encountering mouse integration issues. Doesn't matter if I install guest services, edit confs, or not. I can never seem to get a stable mouse in any virtualized OS and it makes using vBox a nightmare. Anyways, my mouse issue isn't the point of this msg...
I was wondering what virtualization software you use? If it's VMWare, is it worth the $250? Are there other options I might not be aware of? I currently use VirtualBox on a windows platform, do you think it's more stable on a Unix or Linux platform?
Thanks
-dam25
EDIT: I'm willing to setup a dedicated Unix/Linux box if there's a OS that's just "known" for being the stable king for VirtualBox, because it would be nice to do this for free.
Thanks
-dam25
