VirtualPC 2007 is currently in beta and does work with the 32 bit and 64 bit versions of Vista. You can go to the Connect website and apply for the VPC2007 beta and probably get involved.
VirtualPC 2004 does not work with Vista, as a host OS or as a guest.
yea i signed up for beta and the stupid ms installer wont download it. it keeps saying i need to upgrade the installer to dl the file and i just dled the latest version.. prob a bug with their installer running on vista..
