N
NecessaryEvil
Guest
I'm going to set up a Virtual PC image of Windows XP Pro on one of my systems.
I'll have a dedicated NIC for it, and I'll have a dedicated partition for the image.
The question is, is the Virtual PC environment a safe/quarantined one, in that if I get into some bad files(malware, virii, trojans, etc.) it won't affect my physical system? (Assuming no files/folders are shared, and the only physical media the system will be aware of will be CD-ROMs, which it cannot write to anyway).
Or, should I just run adaware and NAV in the virtual environment as well?
