bobn4burton
- Aug 19, 2002
So I've been reading a little bit about RAMdisks. It seems you can improve the performance of your pc a bit by assigning some key portions of your system on the RAMdisk (pagefile, browser cache, etc.).
Well...then I started wondering...what if a guy got 8 gig of memory (now that its so dirty cheap) and assigned 4-5 gig worth to a RAMdisk. Then install a virtual pc on the RAMdisk? You could use the virtual pc for your normal everyday stuff (browsing, office, etc).
And yes I know there are limitations, problems such as you'd lose all data on ramdisk at shutdown. But you could back up the virtual pc image file to hard drive, and just keep your pc running 24x7. Anyways, assuming the obvious limitations were an acceptable trade-off...
1. Is it even possible to install a virtual pc on a RAMdisk (virtual drive)?
2. Would performance increase a lot (such as loading apps because you would have no hdd accessing)?
3. Has anyone tried anything like this before?
