Virtual Memory system cannot boot!!1
swirly
Hi, I cannot boot from my pc, as I turn it on, it gets past the win xp loading screen, then it says "not enough vitual memory to run the program" so it restarts and safe mode will not work!! Please help!!!
Tou say it restarts in safe mode and will not work. Does that mean it will not run in safe mode either? Are you holding the F8 to get to safe mode.
Start>Settings>Control Panel>System>Advanced Tab/Performance Options Button>Advanced
That will get you to the place to resize your virtual memory.
