Virgin to a 4870 ( help needed )
ultimate11
just got my his 4870 today <3 , i was using a nvidia card before so i uninstalled the drivers , and ran cleaner pro and deleted nvidia files and did a shutdown
swap cards , installed drivers(ati 8.7) but there are some catalyst options that i am unable to get.
using 2x22 lcds , did a setup but i recall nvidia option saying 'optimized for dual display/single display' (cannot find a similar option for ati , i dont know if it even matters)
i changed the settings a bit like AA application controled but couldnt figure out how to switch off the vsync also when i run catalyst center the screen blinks black and comes to normal
and last how can i work on custom profile for fan speed control feature ( i know you have to keep it to 30% speed)
