I have a ViewSonic VX922 19 flat panel monitor. It was purchased a year go. It has been working fine up until now. The symptoms are as follows:
Also please post your success stories if you were able to get ViewSonic to RMA your product. This monitor has a three year warranty, ViewSonic HAS to replace it with a new, equivalent, or refurbished part.
I myself am in the process of getting it returned for repair or replacement.
ViewSonics online support is here: http://www.viewsonic.com/contactus/index.htm
- If the monitor has no video source plugged in it will display No Signal as it normally should.
- I have tried this monitor on three different computers using both DVI and VGA. I have tried a standard resolution such as 1024x768 @ 60 Hz. I also have tried the native resolution of 1280x1024 @ 75 Hz.
- If a video source is plugged in the monitor will turn off and the power LED will flash green (Its not in standby, standby is an orange led). Its also not out of range.
