I just discovered that there are at least two versions of the ViewSonic VX2235wm. I just bought another one because the one I had was defective and found some slight differences. The biggest difference is that one is made in China 09/06 and the other in Taiwan 10/06.
These are the specs off the boxes:
Product Dimension
528x483x244(mm)
20.8x19x9.6(in.)
Carton Dimension
575x535x172(mm)
22.6x21.1x6.8(in)
Net weight: 6.8kg (15 lb.)
Gross weight: 9.2kg (20.3 lb.)
Made in China
Product Dimension
524x482x244(mm)
20.6x19x9.6(in.)
Carton Dimension
575x522x150(mm)
22.6x20.5x5.9(in)
Net weight: 6.0kg (13.2 lb.)
Gross weight: 7.5kg (16.5 lb.)
Made in Taiwan
I actually weighed the two on a scale and the Taiwanese one is indeed 2 lbs lighter!
Other differences: (China/Taiwan)
Model # (Found in Information menu): VS11446/VS11349
Standby light: Amber/Orange
Adjustments: More steps/Less steps
Adjustment display: Numerical values/No numerical values
Packing: Placed perpendicular/at angles
Cables: Cheaper/Nicer
Rear Inputs: More together/Spread out, audio in center separately.
I have no idea whether they use the same panels or not. I have no intention of opening the units. Picture quality seems similar though colors look a bit different. I just thought you guys might want to know.
Product Dimension
528x483x244(mm)
20.8x19x9.6(in.)
Carton Dimension
575x535x172(mm)
22.6x21.1x6.8(in)
Made in China
Product Dimension
524x482x244(mm)
20.6x19x9.6(in.)
Carton Dimension
575x522x150(mm)
22.6x20.5x5.9(in)
Made in Taiwan
