Viewsonic VX2035 WM
thezfunk
Well, since search is down I can get away with not searching. What is up with this monitor. I just kind of picked it up as an impulse buy because it impressed me in the store and had nice pecs...I mean specs!...yes specs as well as a nice rebate...good price overall for a 20. Was it a good decision?
Also, what programs do you people use to setup your monitors.
It's a pretty good monitor. It's one up from the VX2025 I got a year ago. Got this one for my mother and when I compare the two side by side, the VX2035 is much better in terms of clarity. I believe this model is also Vista certified.
It's one up from the VX2025... the VX2035 is much better in terms of clarity. I believe this model is also Vista certified.
The VX2025 is a P-MVA, whereas the VX2035 is a TN. Assuming that both panels are using DVI cables and have gone through calibration, the VX2025 should be the better monitor.
