Viewsonic VP912b - Samsung 910t
Bastek
I have both units for a while now ( dual monitor setup) and i can offer my opinion:
Vewsonic is reflective but no more than a black Triinitron tube. Samsung reflects only a faint lightspot but on the VS you can see the bulb. Compare this to glossy or matte photographs.
Wich one you prefer?
VS has very norrow viewing angles ,horizontally are tolerable but vertically are terrible about 20 degrees before huge changes in brightness. Sammy is a winner here.
Screendoor effect is more pronounced on Samsung but not very noticable. Viewsonic wins by a nose with milky creamy natural whites ( one more nose away they both look good).
Color saturation is better (more vibrant) on VS BUT you have to view the screen above center otherwise the top looks darker. 910t looks natural but not vibrant.
Light leakage. yes the VS 912b leaks on all 4 sides you can only see this in a dark-dim room with black screen. Samsung has no light leak.
Text is somewhat crisper on viewsonic i guess because there is no screendor effect.
Blacks look good on both screens- except the light leak on VS.
Bluring-ghosting better on VS but not crt levels.
Vs has better stand, bezel but no software fine-tune utilities. Samsung's Magictune 2.5 is Great.
For general Home use the VP912b is great. For Office use the 910T is better b/c of wide viewing angle -non reflective screen and so-so response time. It's also about $100 less than the Viewsonic.
Technology is so slow, it's unerving. http://www.hardforum.com/newthread.php#
Wink
Thanks for the comparison, Bastek! Based on your review, I bought the 910t sight unseen. It's a terrific monitor for the price!
I don't play games, and for DVD viewing, I already have a big widescreen HDTV, so I mainly surf the net and do word processing. The 910t more than meets my needs.
I love the wide viewing angles, both horizontally and vertically. I slouch down in my chair a lot, so the vertical viewing angles were important to me. The only LCD that I've persoanlly seen that has a better viewing angle than the 910t was the Samsung 193p, but that one is so much more expensive! I'm happy to report that I have no major backlight bleeding problems, nor do I have any dead or stuck pixels.
Some people would say that the colors on the 910t are a bit undersaturated, but I actually prefer it this way. Coming from a home theater background, I loathe monitors which have hyper-saturated colors where it looks like everyone has a tan. The color reproduction on the 910t may not seem as eye-popping as on the Sony HS94P (which I have seen), but, in my opinion, it's more accurate this way.
I do wish that the whites on the 910t would be truly white, however. Right now, there seems to be a slight reddish hue to the whites, no matter how I calibrate it. Oh well. Also, I wish the blacks would not look as washed out, but this is a problem that plagues all LCDs to some degree, not just the 910t.
All in all, I am happy with the monitor. Sure, there are better 19" LCDs out there, but they're also a lot more expensive. I know some people prefer the 17" inch size because of the pixel pitch, but I actually prefer the 19" size because I can sit back farther to read the same thing. Of course, I'd rather have a 21" 1600x1200 LCD... ;)
