Viewsonic VP201s USB Hub
zatoman
After 2 months of working fine, the USB hub on the back of my Viewsonic VP201s died. I like the monitor and really don't feel like messing with returning it just for the hub. Has anyone else had a problem with the USB hub crapping out on the Viewsonic? If it happened to you, would you return the monitor? (I bought the extended warranty from Fry's, so it shouldn't be "that" much trouble.) Thanks for any insight.
Mine did also first they would not work, then they did for a couple day's then Dead again.
I'm sending it back to Dell and going with something else. I use the UBS hubs and if there not going work I have to find something that does.
