Hi I just got a VP201s and it is hooked up with a DVI cable to my X800XT PE. I get artifacts in the form of white flickering horizontal lines.
Enabling the "Reduce DVI frequency" and "Alternate DVI frequency" options in the ATI drivers does significantly reduce the problem, but it still happens in 3D games, and only when the screen has significant black areas.
Has anybody encountered a similar problem and how did you fix this? Could it be the cable? I already re-installed all the drivers and checked the connections of the cable.
Thanks for your help!
