ViewSonic VA2012W 20" 16x10, 1 dead pixel
Nidhogg
today i got a VA2012wb from costco for $399
Type 20.1" color TFT active matrix SXGA LCD
Display Area 17.1" horizontal x 10.7" vertical; 20.1" diagonal
Optimum Resolution 1680x1050
Contrast Ratio 600:1
Viewing Angle 160° horizontal, 145º vertical @ contrast ratio > 5:1
Response Time 8ms
Brightness 300 cd/m2
i like the monitor and its exactly what i wanted. i played afew games and there is no ghosting whatsoever (that i can notice) so thats great.
the only problem i have with it is there is one dead/stuck pixel. it is stuck green.
also brownish/greenish distortion forms around text if you look at it at an angle, like what jpeg does to image quality. but its not there if i look at the monitor directly, but i dont know if this is normal for lcd because this is my first.
i am going to take it back to costco and see if i can get another without any dead pixels
I thought something was a little odd with that too. At Microcenter they had it up above eye level by a good 1ft. I found in the menus that there is a sharpness option and turning it down/off seemed to help. It definitely does look like an oversharpened image when viewed at certain angles. You can simulate the effect with the sharpness slider in the Nvidia contol panel.
{NcsO}ReichstaG said:
Is that a "6 bit" or " 8 bit" panel;
im not sure but its probably 6
thanks, i looked at the sharpness on the monitors menu and it was at 92 so i set it down and it fixed it
Wordsmith9091 said:
The monitor looks sweet - Can it pivot? I just might pick one up myself.
it can pivot up and down and its got a wall mount but it cant really go too far forward facing down on the desk mount
Actually, I meant can it -rotate-, not pivot. Can it be used in portrait mode? I do a lot of newspaper layout, and that would be handy.
Can one really notice the difference in colors between 6bit and 8bit panels?
Check how nobody answered you... lol Theres not a big differnce between the 2 but if your a graphic designer, or photographer I would recommend getting a 8bit panel, other wise if your a gamer the response time is more valuable. When comparing the 2 you can see a difference. In my eyes, a 6bit panel looked more like a crt (dull) and a 8bit panel looked more vibrant, and colorful (this might not be the "bits" it couldn't have been the contrast ratio).. This was comparing average web sites and ut2k4 on a tn 17" and 19"mva. But then again the 6bit panel looked very good too. Anyways, i don't know and I don't think anybody can give you a precise description because we all have different eyes.
Some of the major review sites claim that on 6bit panels human skin tones aren't displayed accurately compared to 8bit panels. I didn't find this a problem after viewing photos taken on my digital camera with my tn panel.
Interesting.
I was thinking of getting taht 20.1inch Sceptre that has a 8bit panel? But I hear that it has "ripping & tearing" problems in games
Interesting.
It is nothing worse than buying a new $400 lcd panel just to find out how badly is blurs (smears), ghosts, and bleeds (backlight). Do your homework and don't rely on fancy graphs and charts. Try to see the monitor in person before you buy.
