Mar 5, 2004 #1 C Creizai Limp Gawd Joined Jan 20, 2004 Messages 218 Title says all .. I'm buying a new monitor and this is the the Top 2 i can afford.
Mar 5, 2004 #2 E eli [H]ard|Gawd Joined Apr 30, 2003 Messages 1,648 http://www.hardforum.com/showthread.php?s=&threadid=737322
Mar 6, 2004 #3 C Creizai Limp Gawd Joined Jan 20, 2004 Messages 218 Viewsonic G95F is same as P95F? ok cool before I thought they were different ...
Mar 6, 2004 #4 B Blown Cap Limp Gawd Joined Dec 14, 2002 Messages 269 There isn't a G95f, it's the G90f. And it's different than the P95f+. G90f is the Graphic Series, while P95f+ is the Pro Series. Both are 19".
Mar 8, 2004 #5 IdiotInCharge NVIDIA SHILL Joined Jun 13, 2003 Messages 14,669 The NEC is .24, the Viewsonic is .25-.27. I have a Viewsonic P95f+, and it does get substantially blurry at 1600x1200. I would easily suggest getting the NEC, as the pitch of the pixels would allow for a sharper image.
