View 4.6 upgrade to 5
farscapesg1
Just wanting to toss this out there and make sure I understand the upgrade steps right. My current View environment is running on a single Dell R710 with 48GB ram and 2 6-core processors. It was orginally built as a test enviroment and runs about 25 desktops. The workstations are split between training systems (clinical application that requires static IPs, so I had the network team reserve DHCP address by the virtual MAC addresses of the systems) and virtual desktops for our service desk running WinXP for some software that doesn't run on Windows 7 yet.
I'll be adding an additional host to the cluster as well as increasing the memory to 96 GB on both hosts. Currently we are only using vCenter, Composer, and View Connection Server. We don't currently allow access to the View environment from outside the network.
From reading up, my understanding is that I should do the following.
1) Install ESXi 5 on the new host (another Dell R710) and attach it to the SAN
2) Upgrade vCenter and Composer (running on the same virtual machine in our production ESXi cluster)
3) Upgrade the View Connection Server
4) Add the new host to the cluster
5) Migrate the VMs to the new host
6) Remove the old host from the cluster
7) Shut down the old host, add memory, install ESXi, configure SAN access
8) Add the upgraded host to the cluster
The good part is since it is only training and limited use by the service desk, downtime shouldn't be an issue. Bad news is I need to make sure that the virtual linked-clone workstations stay configured as they are (specifically MAC addresses).
Am I missing anything? Got something out of order?
I would download the latest vSphere 5.x and View 5.1 Documentation. Make sure that you have a Reverse Lookup Zone within your DNS and a PTR record for your vCenter server as vCenter 5 install requires it now during the install...but this may not be an issue in your case. It was for me when I reinstalled and linked to the new DB server.
Are you also going to the latest View 5.1? There are some changes around SSL Certs. If so, please check this:
www.vmware.com/support/view51/doc/README.rtf
https://pubs.vmware.com/view-51/topic/com.vmware.ICbase/PDF/view-51-upgrades.pdf
Keep us posted on how it goes. I did this in my home lab and followed the guides above. Of course I also migrated off of SQL Express 2008 to SQL 2k8 R2 so there were other steps as well. We are going to be upgrading at work soon.
erm...
You've got some steps out of order.
1. Upgrade VC to 5.
2. Upgrade View to 5.
3. Upgrade Composer to latest.
4. Upgrade View Agent in VMs.
5. Upgrade hosts.
Hosts are always last.
Thanks lopoetve and vader!
As to the hosts... i figured I could install one ahead of time since it is a new server not currently in the cluster (yes.. the cluster only had 1 host in it :) ). I guess on of the additional issues I'm throwing in is that I prefer to do a clean ESXi install on the existing host instead of just upgrading. Just a personal preference on my part. Maybe I'll rethink this though :)
Completely forgot about the view Agent... thanks for catching that!
I also like to do a clean ESXi install! Let us know how it goes. Some peeps say do the Agent first as 4.6 is not compatible with 5.x but it works the other way around but I guess you can have down time etc. and you'll be taking down View/vCenter anyway.
Personally I've found it best to upgrade the agent last. I've had it work out just fine upgrading it first but more times then not I've ran into issues.
Since upgrading to View 5.0.1 I've been following the steps VMware suggests in the vSphere Upgrade Guide documentation which is as follows:
1. Upgrade VMware Tools
2. Upgrade Virtual Hardware
3. Upgrade View Agent
That's a good point, we didn't even mention the update of VMware Tools and Virtual Hardware. I know I had issues in 4.6 installing the VMware Tools prior to the Agent..or vice-versa...can't recall right now..my brain is toast...
