Videocard Upgrade Advise please.
personally i would buy the x800xt and stick it in your a64 system and move the 6800 gt to the athlon xp system. the x800 xt is faster than the 6800gt
How much are you going to use the all in wonder stuff if you go with that card? On the other side how much gaming are you going to be doing on this machine?
If you can spare the extra $45 I would go with the AIW personally. :)
Yup, seems ilke the ideal thing to do.
I use both systems mainly for gaming. I doubt I will use the extra AIW features much, but the pricing on this card seems preety good compaired to the regular X800XT's right now.
QFT
wow, teh x800xt is only 45 bucks more than the 6800gt after rebate..I would get the XT since it is a better card and has AIW and only 45 bucks more :)
