Videocard Temps?
Zatos
Is there a program that will display your videocard temp?
Forgive the stupid question, but I've been trying to search for it
and its taking too much time to find some relevant information, so I figured I'd ask!
Thanks
rivatuner, atitool, and it shud say in your display properties if you have an nv card (dunno about ati)
Sorry, I guess I'm dumb because I can't figure it out... I see in there options for Core Temps... but as far as how to get it to tell me... I'm clueless. :confused: :(
EVEREST Ultimate will tell you, but it's overkill for just video card temperatures (it is a VERY good program though).
What program are you poking around in right now?
It also depends on the videocard model, not all have thermal sensors on board.
Those that do from Nvidia/ATi allow you to monitor temps in the advanced control panel.
Some programs like Ati Tray Tool amd RivaTuner reference those temps and can display them constantly in your tool bar.
So first step is to specify your GPU model, to see if it even has a thermal sensor onboard (If its the one in your sig, then there's no chance in hell).
What card do you have?
