Videocard Support Bracket
Seithennin
Does anyone know of a bracket that can be purchased to support my Radeon HD3850 card? like the cardkeeper that fits the nvidia cards?
I would think that simply putting the card in the pci-express slot and putting a screw in would be enough.....
It will be fine.... unless you are hanging a 5 lb dumbbell off your card you will be fine...
