video wall??
QwertyJuan
Anyone set one of these up?
Place where I work wants to replace our projector and screen with a video wall. Wanting to use 2 x 2 70" panels, to give us roughly the same size as we currently have.
Any tips, tricks, ideas??
Make sure to make that bezel as small as possible. 2x2 sucks as you have bezels in the middle of you screen. Also if you do a video wall that just uses a single 1080p hdmi / dvi jack and tiles, it will be easy to setup, but you will have a lot of lag due to processing and the screen will have to be upscaled. They are things to think of. What's the major use for it? TV/Movies? Games?
Are you not satisfied with the projector? Is it old? May want to review newer ones.
No, they are not happy with the projector...it's not bright enough, and we want tp go widescreen anyhow.
Never thought of a 2x2 having the main break being in the center. That would make a difference for sure.
