Video Tearing.... x1950
Cele-CT
Well, I just hooked up my HDTV to my pc and formatted my machine while I was at it. (Vista)
Now, any video that I playback I am getting some tearing along the bottom a little bit and a little on the top area. Now I have used many different drivers and still running into the issue. It is not only on the HDTV but also my monitor so I think it should be caused by software mainly.
Any ideas?
Most tearing effects are usually caused by memory instability. If you're not overclocking your memory, then maybe the memory is dying. I'd try throwing a nother video card into your system and/or putting that video card into another system and seeing if the problem still exists. If it does, then it could be a memory problem.
Oh and by memory, I mean the onboard video GDDR3, not system RAM.
Good luck!
Yea , I will have to look into cleaning it out (the HSF on the card) and see if that helps. It is not like bad bad ... just once in a while it is noticeable.
Thanks for the idea !
