Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Can I enable the video and system BIOS to be cacheable in my BIOS? I read in my mobo manual that if anything tried to write to the memory then it buggers up but what kind of risk is it really?
I was in a rush, forgive, I'm gonna backpeadal a little here.
In all the systems I've owned, the system bios was default cached "on", and I had no issues with the setting, so I left it that way. Heres the deal: In both system and video bios', having them cached essentially enables caching of the system BIOS ROM at F0000h-FFFFFh via the L2 cache/video BIOS ROM at C0000h-C7FFFh via the L2 cache. This greatly speeds up accesses to the system or video BIOS. However, this does not translate into better system performance because the OS does not need to access these BIOS's much. Specifically in the video bios : this does not translate into better system performance because the OS bypasses the BIOS using the graphics driver to access the video card's hardware directly.
As such, it probably would be a waste of L2 cache bandwidth to cache the system or video BIOS instead of data that are more critical to the system's performance. In addition, if any program writes into this memory area, it COULD result in a system crash(altho I havnt seen it, which is why ive left the system cache alone).
I have set Video BIOS and System BIOS cacheable both to disable and have not encountered problems. Modern OSes rarely touch the BIOS now (if ever); these settings are more of legacy settings than anything else. It's okay to disable them and get back some precious L2 cache in general.
