Looking for some recommendations on a video production build.. mainly premier encoding with HD video, photoshop, etc. building it for work
I'm assuming the best would be Core I7?
Components I need: all minus the monitor, unless you can fit in another 19" currently have a dell 19" ultrasharp we are using here... if you guys leave enough room I'll get the matching monitor myself.
Case can be fugly, don't care about looks as no one is seeing it.
Budget: $2500
Requirement: 2TB of disk space.
Buying time: Within the next 5 days.
If you have a better monitor suggestion that fits in the budget I'm open for suggestions!
/edit - preferred newegg or 1 retailer for all parts, makes purchasing orders easier to submit.
/edit 2 - spose I should answer the questions as well..
HD Video editing, photoshop, web, etc
2) What's your budget? Are tax and shipping included? $2,500 Firm - no room going over, not even 1 cent included taxes and shipping.
3) Where do you live? NC - 28804
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific. All minus monitor
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. - Monitor Dell Ultrasharp 19"
6) Will you be overclocking? No
7) What size monitor do you have and/or plan to have? 19" Dell Ultrasharp
8) When do you plan on building/buying the PC? Within the next 5 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. SLI not required Need 2TB of disk space
10) Do you already have a legit and reusable/transferable OS key/license? Unknown right now
Budget: $2500
