video driver for gateway fx?
HaX
What are other gateway fx users using for video drivers? I was receiving some errors when trying to install drivers form laptopvideo2go.
I recently bought a 6860FX
Put 174.74 drivers I downloaded from laptopvideo2go.com
The key is to copy the correct .inf file out of original(s).inf into the main directory.
So far so good.
I did it for both by Vista 64 Boot and Windows XP Boot.
I'll give it another try.. i don't remember what drivers I was using but the modified .inf file wouldn't work. 174.74 seem to be the good ones, yes?
I tried installing the 174.74 drivers but I get this message:
"The system has not been modified. To install this program at a later time, run the installation again. "
Then gives the option to restart computer. Even if I do restart the machine and try to install the driver again, I get the same message.
Yes .74 seem to be the best for me.
As for installation.
I DID NOT download the modified inf file. I only downloaded the driver from laptopvideo2go.com
Unzipped it into a folder
Within the folder there is a subfolder called original(s)
Copyied the nvdisp.ini file from the subfolder into the main.
Uninstalled teh current drivers and let the laptop reboot and install the Standard VGA XP driver.
Then from the device manger did update driver for the display device, selected have disk and pointed to the nvdisp.ini file in the folder.
this worked, now getting around 8700 on 3DMark06
