Video Cards and Brightness Settings
Sterling
HI All
I just purchased two samsung 730b monitors for my business. I still use Matrox G550 which are over 5 years old. I like they render Text so Clearly. However, these monitors are extremely bright. I have both the Brightness and the Contrast turned all the way down to zero and find these two monitors painful to view. I have also tried adjusting colors with no avail. Tried using both manual and automatic adjustments with no success. These monitors are just way to bright for business applications. Do new video cards have settings to control brightness? By the way, i just came back from the Dell Kiosk at the nearby mall and find their monitor brightness adjustment is very limited too.
thanks
Sterling said:
HI All
thanks
I feel your pain. When my crt's contrast is turned all the way up it hurts the fuck out of my eyes.... As far as new videocards go, I know NVIDIA has an option for brightness and Contrast in it's control panel, and i think ATI does to.
ATI has the catalyst Control panel (if you use the offical drivers) which allow you to change the gamma/contrast both for fullscreen and window promgrams seperately
Right click on a spot on your screen that has no icons, select "properties" at the bottom of the drop down menu, then a box will pop up with your screen saver settings and other things, the last one should say "settings" click on that, then click on "advanced". One of the tabs on that screen should have the name of your video card on it, click on that and one of it's selections should have an adjustment for brightness and colors, bring the brightness down in that panel and you should have less eye strain. BTW, sometimes it's called "Gamma".
