Most pf people have said to go for an new PC.but at the time i cant afford that due to budgeting problems.so im now trying to upgrade my pc by buying a new video card to play some games.These are my system specs.i think this details will help me to buy a suitable VGA for my PC.
http://www.google.lk/url?sa=t&rct= [...] bs.1,d.bmk
Intel(R) Pentium(R) Dual CPU
E2160 @ 1.80GHz
1GB RAM DDR2 System Slot 1 PCIE X16 SLOT
Motherboard INTEL
Model D945GCCR
Chipset Intel i945G
GPU INTEL 82852/82855GM/GME
PSU 450W
CPU Code Name Concore
Number of cores 2
Vendor GeniuneIntel
Number of Bits 64
Platform Name Socket 775LGA
Revision L2
Original Colock 1800MHz
Theses VGA cards are available. Nvidia Gt210 1GB,Nvidia GT520 1GB(Used one) and Nvidia GT610 1GB,Raedon HD5450,Raedon 6450.I think that GT 210 will suit but it will not suitable for games.Is it okay for me to buy the used one or is NvidiaGT 610 will work on my PC.Whats is the best one that will suit my PC.im going to buy a one so can anyone tell me what type of card that i need to buy.
E2160 @ 1.80GHz
Motherboard INTEL
Model D945GCCR
Chipset Intel i945G
PSU 450W
Number of cores 2
Vendor GeniuneIntel
Number of Bits 64
Revision L2
