Video card with hdmi
vincer20
is there any other cards besides the x1600pro. i own a 6600gt is this a downgrade or upgrade
Apparently the next wave of cards will have the HDMI interface. It was just like HDCP, now there are beginning to show up.
I would just go get yourself a DVI to HDMI cable and wait for the cards that you want to have it rather than vise versa.
there is a dvi to hdmi cable???? does that make any sense at all??? i dont see how using an older port to a newer port makes a difference at all i mean why not keep the same thing.
it makes sense if your telivision doesn't have DVI. a lot of the newer LCD tvs just have HDMI and VGA.
I wouldnt be able to type to you if there wasnt. I have my 7800 GTX to my LG plasma running 720p right now.
Monster Cable has had them out for a long time. And honestly the only difference between HDMI and DVI is DVI wont carry the sound as well as image data.
And yes my PDP doesnt have a DVI port, just HDMI and VGA, and screw analog:)
then how can you have a dvi to hdmi converter if dvi doesnt transfer sound in the first place.........
HDMI can carry both audio and video... but it doesn't HAVE to carry BOTH of them... you can make it carry just audio or just video too.
If you use a DVI to HDMI you have to provide an additional sound source... most tv's with HDMI has L/R jacks right next to the HDMI jack for audio provided from a non audio HDMI source.
Its not like your TV has more than 2 channels built in so its not that big of a deal to have digital sound data coming through HDMI. But sure it'll simplify connections between high definition disc players to TVs. You should probably have a component audio system to compliment your HDTV anyways. But eventually somebody will make some kind of adapter that will let you feed audio from a computer into a HDMI cable.
why are you in such disbeliefe?
is it so hard to believe?
Here ill get a picture of one for you since you seem to not believe they exist....
